When you use the word "pump" do you mean a MiniVac. Or do you mean "pumping the pedal"
(EDIT)
, sorry, I mean VAC
Lets back up. Disconnect everything (switch, banjo bolt, brakeline etc) off the mastercylinder. Can you now pump the brake pedal and see fluid squirting out the hole.
It should weep fluid slowly without even pumping the pedal. But when you press down on the pedal, it should squirt a nice shot of fluid.
Possible seals in master cylinder are weak or rolled over
