I wonder what type of brake pads are being used and if there isn't an aftermarket set available that would work better. I wonder if they're using organic pads, maybe an upgrade to sintered if the rotors can handle it. :34:
I believe the situation is the size of the rear calipers and the number of pistons to operate them.
The Tri Glide uses dual discs up front being clamped by a pair of 4-piston calipers while the rear has a disc on each wheel and single piston calipers. The front brakes could use a bit better grasp on the rotors, but a firm squeeze on the lever does slow the Tri Glide quite adequately. The rear brakes take a very firm push on the pedal to effectively activate both rear calipers in order to slow the trike down. Once I was accustomed to the required pressure on the brake pedal, the rear brakes do a very good job of bringing the Tri Glide to a stop. The parking brake, located on the right side in front of the rear fender and could be quite a stretch for some to apply, is integrated for use with the rear brake calipers.
Above quote from Motorcycle Mojo Magazine 2009.
Cure for the problem and this needs to go to HD: Larger bore master cylinder for rear, larger rotors and bigger calipers. The same as the trike conversions use.
Do you know how people always say, "Read the instructions!". I started to analyze information on the Tri-glide rear brakes and some people say theirs are good and others are saying theirs aren't right. There is a paragraph in the service manual that reads, 'When replacing a bleeder valve in the rear brake caliper, remove the O-ring from the bleeder valve groove or bore and discard. The O-ring is required only for brake bleeding at the factory. Although not sold seperatly, it may be present in certain assemblies as curently sold. If care is not taken to remove and discard the O-ring, it may become lodged in the bore during bleeder valve installation and prevent proper torquing or sealing.
It seems like every time the brakes go in for service, they are about the same; maybe the O-ring is down inside the bore or there is no seal in the brake system at the bleeder and air is coming into the system. Just a thought after reading it in the service manual.
I need someone who is having a problem with their Tri-glide to try this out, order a set of the best quality Lyndall Racing Brake Pads for the trike (have the dealer do it since it's under warranty). Put a better quality brake pad on the trike, remove the questionable O-ring and bleed the system from the completely. The brakes are the 'Weak Link' on this trike, think of all the conversion units on the road and how they are constructed.
