J
Jack Klarich
Guest
Harley Davidson Forums Pick up one of these and check for spark at both cylinders, wear gloves and bend the wires to double check Wiggle the injector wires also to see if it improves the running
I will take it out for a ride tomorrow after work and see what the plugs have to say and report back.
A stock TC88 should show about 160psi, or thereabouts, at sea level if the top end is in good condition. So, either you are located 5000 feet above sea level, the test was not done correctly
