J
Jack Klarich
Guest
The biggest thing to understand is the square cut o ring in the calipers not only seal the brake fluid from leaking out , but also keep a slight drag on the brake , you would notice it more on the rear brake because of less air flow. The disc brakes are meant to run with 0 clearance so they are ready when you are, kind of like residual pressure in old drum brakes with wheel cylinders, hope this helps
