USE the Torque wrench specks and Blue lock-tight..It will be fine.
The thing I wanted to say about checking tightness of Bolts that have been TORQUED DOWN ONCE.(.) and WITH any type of Lock-tight is used.
I DON"T EVER go back LATER and check them. NEVER... Once tight they are to BE Left Alone.
Take for instance, Head Bolts,,, IF you go back and RE-torque them YOU'll Ruin the seal of the head gasket IF tightened EVEN a LITTLE, Or break the head bolt....
Any movement of a "Finished" Torqued bolt WILL cause a problem with the Gasket Seal OR the Lock-tight that HAS Keep it tight.. Never Move one like that...
I NEVER MONKEY With something that is Torqued ONCE and that is it period..
I,,,,,notice i said I ,,,,, Can't stand the expression used by Many that say I CHECKED ALL MY BOLTS To see if they were TIGHT.. NO WAY is that Correct to do.......
Yes there are Many bolts ,screws,nuts and parts on a bike that can be checked for tightness, Exhaust on occasion, snake skins, etc... BUT I refrain from Quite a few.
NOW this IS ME....
I just Plain DON"'T have many things I lock tight or Gasket' together come LOOSE.. If done Right the first time It should stay tight.. Don't Ruin a good Seal.
I DO look and even "finger" a head bolt or Others and Have found a few like the derby cover loose But I still don't take a wrench "Every Time" after a ride to check to see IF things will Tighten MORE.. REMEMBER, they Have to Come Apart...
Just MY Way...AND Suggesting it for you also.
Rant and Rave
