J
Jack Klarich
Guest
Thank you for the web site. They say for 2 up the psi should be46-48 for the rear.Thanks Again.
Happy riding and be safe, let us know how the tires feel and wear intruding minds want to know:s
can 2 psi ( 36/38) really make much of a difference? I dont even think our usual tire guages are that accurate anyway.
Bill
2 or 3 psi low increases the sidewall flex which in turn creates heat. I have the Doran Tire Pressure Monitors on my RK so I can continually check the pressure differential from cold to hot. Unless you have this unit it is a pain to do this kind of checking. This unit is also very accurate, measuring pressures to half a pound. You are right about cheap gauges being inaccurate as I have seen the as much as 10 pounds out when compared to the digital readout on the monitor. Using the 4 to 5 pound hot increase to set the cold pressure is a good way to get things right for whatever you ride as mentioned in previous post.
I remember a few years back being shocked at the difference my little checkers were showing. I pulled one out of the wife's car and it was terrible so I got rid of that one. Now I use one that is combination checker and filler and I don't mess with any others. So I'm right with you about not going for the ¼ pound psi. I pick a number and keep it there. Now I got nitrogen in the wifes car you don't need a special one for that do you?thanks for your response. As for me, I run my tires at the 2-up load PSI recommendations and keep them there. Very seldom do I ride alone. Was just saying -- 36 in rear tire while riding alone and 38 when riding with passenger - I dont keep switching back and forth --- thinking 2 PSI doesn't make a lot of difference in that case. PLUS I dont have a gage that accurate in the first place. -- perhaps I should get one.
Bill
Without even paying extra, you get 80% nitrogen out of any air compressor.
Really I've never heard about this, in fact I was wondering if I could put air in the tire on top of Nitrogen. Obviously I know you can but I wasn't part of the nitrogen deal on the Wife's car, in fact it is a cool story My neighbor gave my wife the car....1991 300 SEL Mercedes 100,000 miles and put $3800 in work on the engine before he gave it to her. $59,000 new in 91.
