Tyre tread should be measured at the deepest point of the tread i use a tread depth guage it does not cost much and does not wear out as i am in the uk minimum legal depth is 1.8mm for a car and 1 mm for a motorcycle
Draper Tyre Tread Depth Gauge Part No: TG92
F.B.,
"Where do you measure tread depth?
At the wear indicator?"
Yes
Al
:USA
:CONNECTICUT
I wrote to Dunlop and asked this question:
"Where do you measure tread depth? Is it on top of tread wear indicator, or, deepest part of used tread?"
Dunlop's reply:
"Recommend you stick the tire in 3 different places.
This should give you a good tread depth.
If you are unable to determine the tread depth, stop in at a reputable dealer for assistance.
Should you need further information or assistance, please call Dunlop Consumer Affairs @ 800-845-8378 "
I guess I have to call them.
It becomes a lb per sq inch thing. Wider tire with same air pressure as narrow tire will have less actual pressure pushing on the pavement as its spread out over a wider contact patch. That's one reason its much easier to spin wider street tires on a car/truck, or a mc.
If you want to increase the traction for either tire you have to let more air out, say 10 % or so will improve the grip as it softens the tire slightly and allows the tire to work better. If you ever take a bike with street tires to a riding course, you'll find that they will lower the air pressure front & back to give the tires some help in doing the turns etc.
What are the chicken strips ? i have 5200 on my 200 mm tire and have maybe 1000 miles left on them .
LOL ok now I have to look at mine
