Hey Glider,
Got one question for you. I can't figure this one out. You know when I put the rear wheel back on, I put everything back just like it was. Spacers and everything. Like I said I marked the Adjuster Cams and got them all lined up and everything. Belt has the correct about of movement. But when I look at rear wheel from the back, it does not look like it is in the center of the rear fender. Maybe my eyes are off or something, but it looks like the whole wheel is shifted to the left (Standing behind the bike looking towards the front.) But when I took it for a ride, and looked at how the tread where was on the tire it looked even all the way across the tire.
I jacked the bike back up in the air, and it spins free with out any problems, and I don't hear any kind of binding noise other than the new rear brake pads I replaced. Am I just imagining things? Or what? I know there is no vertical alignment called out, at least not in the service manual, but how about the Horizontal alignment. It that not adjusted with the Adjuster Cams on the axle? I torqued it down according to the service manual to 95 to 103 lbs of torquer.
