The 6L027 bearing you purchased is a 6205. The outer and inner races on a 6205 are flush with one another. The inner race does not protrude out.
Let me save you some time and grief. If you were to measure the distance between the bearing shoulders in the wheel hub you would find that this measurement to be appox .180" shorter than the bearing spacer inside the wheel hub. This is done on purpose by the MoCo.
When you begin to assemble the new bearings with your wheel, you MUST press the brake rotor side bearing in FIRST to the bearing shoulder of the wheel hub. Then insert the bearing spacer from the belt pulley side. You must then press the new bearing in on the belt pulley side ONLY until it touches the spacer. Do NOT press it to the shoulder. If you do, you will press OUT the brake rotor side bearing which will cause all sorts of clearance problems with your caliper and disc rotor.
Everything is built on the distance from the brake rotor side bearing. Position of the wheel, belt, caliper, rotor are all built on the starting point of the brake rotor side bearing. That bearing must be flush with it's hub shoulder.
