Temps are dropping quickly. I checked my tire pressures and they were a little low, so I put 1lb less than what was listed on the sidewalls. Seems to ride better....but, what is the best tire pressure for my 09 Street Glide?
Happy Thanksgiving.
Just remember -- the PSI on the sidewalls are MAX pressures!!!!!
Is that when the tires are inflated Cold. Or is that the max pressure under any circumstance (Hot)?
I am guessing that is the Max pressure when cold but I don't really know.
Happy Thanksgiving.
Maximum pressure isn't necessarily the recomened pressure. It's best to check your owners manual.
The sidewall imprint only specifies the "absolute" max. cold pressure value, which is likely 10 PSI or more OVERINFLATED if compared to the actual HD factory manufacturer recommendation. :small3d002:
BINGO! Owner's manual will tell you the recommended pressure and takes precedence over the max pressure stamped on the sidewall.
How can you say the owners manual takes precedence over the Tire Manufacturer? I would believe the Tire manufacturer over the Bike manufacturer.
Remember when the Shuttle manufacturer said they were right over the "O"ring manufacturer?
