Bikergeek
UPDATE to my previous posting;
I tried to remove the glass (mirror) from the mirror assembly by heating it with a heat gun and I suppose I was a bit hasty in trying to remove the mirror and it cracked in half but it is taped together in the back so it stayed together. But...I did it it off in one piece. That glue is quite amazing stuff tho! I drilled a hole through the back of the mirror and through the tension plate that the swivel ball rests on and added a screw through the back and tightened it up. It definitely helped fix it. So I applied a bit of Locktite to the threads and I will reglue the mirror back on (by reheating the existing glue) just for the heck of it. It is useable but will not look very "pretty".
I'll keep it for a backup mirror.
