Crocker
This is somthing you dont want to do, you will be setting your self up to lose control over your bike very easly when braking , most experts agree that 70% of your braking is done on your front wheel , and 30 % on rear brakes, when you brake you are transfering most of the bikes weight toward the front of the motorcycle hence needing enough brake to equalize the transfer of weight, it is more likly that if you remove one of your front calipers , you will be putting yourself in a position to use to much back brake and setting yourself up for fishtailing because of the weight transfer you will find your rear brakes locking up often and throwing your bike in to fishtailing conditions.
