normally vibration will work bolts etc. loose or break them off, as i had on a 09 trike, the steering dampener bolts (1 broke off in the head) and the other fell on the hwy. i used a lower grade replacement bolt (so if it happens again i can drill the bolt for a e-z out. also used anti-seize and safety-wired the bolt heads.
I would NOT RECOMMEND that for 2 reasons...the lower grade bolt would break easier, and if it happened on the road, you really would not care if a drill could cut through it easier...bouncing down the road along side your bike. :hii
I would go with higher grade bolt, anti-seize and properly torqued. H-D does it's research, and 01dynaglide's failure I believe is an isolated case, but one worth noting in your maintenance notes :newsmile091:
