free website stats program road king running erratic | Page 2 | Harley Davidson Forums
If it hasn't been changed from 2008, the main gas connector under the tank is a quick release which will not flow fuel when disconnected negating the need to drain the tank. A drop or 2 will come out during the disconnection. The fuel gauge plug will need to be disconnected, also under the left side and the vapor hose on the top of the tank and running back to the back end of the tank is plastic and has a short hose between 2 sections which can be pulled apart. A manual would be an invaluable as a guide for all of this.
thxz for info..............
Can you not disconnect Fueler at ECM and just connect in factory harness back into ECM with out removing fuel tank????? :33:
there are 6 wires in a sleave from the fueler heading under a blk plastic shield (just before the tank) then i guess under the tank to connect with another cable or split and connect where ever. and 1 blk wire from fueler heading under the left side panel.
the ecm is the finned unit sitting on top of the battery ? this has one heavy duty snapp in connector which sems to be part of factory harness. nothing from the fuler goes directly to the finned unit above battory (ecm?)
