J
Jack Klarich
Guest
Well there's an idea I hadn't thought of!! Good one, Bubbie!
Trying to figure something out, though...
First, the Rocker Cover (top plate) is held on by four bolts to the bottom plate. One of these four is now stripped out (the hole, not the bolt). What I am trying to ascertain is this: If I took the bottom plate off, could I look through the mounting bolt hole, or is it only threaded partially through the plate.
Harley Davidson Community
The reason I ask is that I don't want to screw something further down into the hole and have it obstruct moving parts beneath the bottom plate. Does anyone know the answer to this question? I know my depth gauge is bottoming-out, but WHAT is it bottoming-out on - the bottom of the hole, or something in the head?
That is a blind hole meaning it ends, the lower rocker cover mounts to the head with bigger cap screws. IMO the bedt way is to replace the lower cover, I do not think there is enough material to drill out and install a time sert, however this is not a critical torque so you may use the Permatex thread repair here and call it a day JMO
