cdn-bigfoot
Junior Member
It's just a cheap lousy lock in a ridiculously stupid place. I took mine off altogether and replaced it with a Softail style switch on my dash. I had to drill a hole in the dash. i had the dash chromed while I was at it.
If you're looking for a cheap and easy fix while keeping the current switch.
I saw on another post that if you grind off the little nib on the key you can turn the key and pull it out and pocket it like I do with my new switch.
Here's the discussion on grinding off the nib so you can remove your key when turned on.
Simple fix to the "flopping key" on a Dyna
