It might be that you did it different in that you retained the standard brake tail light when you added the mod. Most riders I think "pitch" the standard incandescent light one for aftermarket LED type by Küryakyn and others...yeah, yeah another $125 to $150, but JMO. :s
as said they dont get much brighter unless you add the LED stoplight
Mainestreetglide; Does your module have heat shrink covering the components or is it a totally sealed unit? H.D. has changed them from the former to the latter, and I think the new ones have better light levels. I want to get a run/turn/stop module, but keep reading about the brightness problem. I know there's at least 3 other brands, but they are more than H.D.'s.
NEWHD74FAN & Bud White, are you talking about changing the original stop/tail light or the directionals (which are now also stop/tail lights) to LED? If it's the original stop/tail, I'm confused on why changing that light to LED would impact the new stop/tail setup for the directionals.
Breeze3at, I'll check it out sometime this weekend and let you know.
