fin_676 Experienced Member Staff member Moderator Contributor Apr 6, 2010 #11 If it is a float needle youll need to check the float height after you ahve fitted it also ensure you clean the area it seats prior to fitting it Brian
7 79mr79 Member Apr 10, 2010 #12 Thanks guys, cleaned the carb, changed the needle seat, oil, and plugs. Firing on both cylinders now. Got some carb adjusting to do. It runs real rich, it always has. I think I'll post my questions in the carb thread. Thanks!!
G glider Veteran Member Apr 10, 2010 #13 Post the size jets you are running. Shouldn't be over a 46 low jet.
