RibEye
Senior Member
Can't be the plugs. They're brand new.
As for taking the TFI out of the circuit, I will have to put the original air box back on, as it does not have a stage-1 download. The TFI is supposed to relieve the lean condition resulting from Hooker slip-ons and Stage-1 airbox. I can do it. It is just not on my list of firsts.
Intake leak is possible, I suppose. The indy that did some work some time back, said they sprayed starter fluid in the vicinity of the intake seals, with no change in idle, so that shows no intake leak. I don't know. Sounds reasonable. They said they tightened the rear exhaust manifold connection, and it did seem to clear up for a while, but it has been cold since Nov.
I have had exhaust-related gaskets and clamps on order from Chicago Harley for 2 months now. Once I get those put in (if I ever get them), I will have eliminated exhaust side leaks (also possible with warmup and vibration). I will then order what I need to eliminate any potential intake leaks. I also intend to order a fuel pressure gauge and adapter, in case the fuel lines in the tank have developed new holes (was the case 2500 miles ago).
Symptoms are not the same as when there were fuel line holes: started hard, tank hissed when idling for a while, seemed to happen regardless of warmup time. This time, she starts right up, and seems to need warm up, shorter time as weather warms up. When the temp is the same, on the way to and from work, it seems that the location where it begins is similar each time (equates to time and/or distance).
If it were fuel pressure or injector wiring issues, warmup would not be a factor, unless the issue is in fuel injector drivers or fuel pump or fuel pressure regulator.
I have a new CPK sensor. I have not put it in, as easy starting and warmup does not lead me to that sensor. I suppose engine temp, MAP or TPS sensors are possible.
So many things can cause this. I just hoped that someone had similar issues, and it was a common problem. Troubleshooting without the proper test equipment and gear is a pain.
I just hope it is not the ECM...
Enjoy,
Rich P
Enjoy,
Rich P
