Ok, here is what I got: '02 Dyna WG, stock as far as I know.
Supposedly running reasonable, then coming to stop light, started running rough, won't idle, black smoke out of pipes, black spark plugs.
1.Done so far: Diaphragm had a chunk out of the lip – replaced – no change.
2.Intake manifold o-rings chewed up a bit – replaced – no change.
3.Error code – 02 – MAP sensor – replaced – no change.
4.Took to dealership, had error code reset, seem to run ok, my opinion, it was idle to low.
5.Next morn, same problem as at beginning.
6.Dealership didn't say any problem with ignition module.
7.Changed spark plugs – no change.
8.Check coil – resistances ok – no change.
9.Someone hooked up LED lights – did terrible wiring in tail light – fixed – no change.
I think I have basically run out of options.
Anyone got a solution I haven't looked at yet?
Happy Trails.....
