RibEye
Senior Member
Very big help. I am more than likely going to change to a Gates brand submersible fuel line hose (5/16 id) and not even bother trying to find the HD replacement line. Today is Sunday so no luck at any of my local parts places as they are closed. May require a 70 mile trip to Port Angeles to NAPA.
right now my hang up is my noobness. I have the console off and the fuel pump plate cover unscrewed, but getting the assembly out is proving to be a bit daunting. All the components are plastic and if I bung it up, seems to be costly to fix...I am reading the HD shop bible, and it is kind of vague on how to manipulate the assembly out. Any advice would be appreciated.
One question, My tank level is well below half tank, how important is it to drain the tank (no open heat sources or flame) before I gently remove the assembly and replace lines??
I strongly recommend a fuel rail pressure test before repair work or part purchases. You could wind up doing significant, and costly tail chasing. There are many possible causes for your symptoms.
You do not need to remove the tank to replace its guts. There is a trick to getting those guts to come out, which is likely spoken about in the self-help area. Once you have done it, it is no problem, but it is kind of tricky teh first time.
Be careful about using non-OEM fuel line. It must be submersable, and it should not have an outer surface that could rub the tank lining off where it contacts it. Do not try to re-use the fuel line clamps. Watch the routing of tank internals, to make sure they do not interfere with your fuel level sensor motion. You need brand new sealing screws for the console, as well as a new seal, then make sure you follow the torquing sequence for the console screws. it will help to put the new seal in the sun to soften it up, before installing it, also, it is best not to install the console and seal in the cold. The seal is kind of hard rubber.
There is more. These are just the biggies that occur tome at the moment...
Good luck,
Rich P
