hey dolt, you ought to be a salesman, I think I'm going to a bigger bore. do you have a phone number for the head porting shop by you. whats your take on the S&S 97 in. big bore kit, includes cylinders, pistons, rings, wrist pins, gaskets, and free shipping for $710.00 . the kit says it would have 9.7 to 1 compression plus my heads have been milled 050. with a .030 gasket what would you estimate the compression to be.
OK, I am going to lay out a program for ya that will save you some money.
I don't know where you live but the shops I am familiar with may not be in your neighborhood. I will be happy to give you the contact information for Lozano's Brothers Porting; Mike does offer a 98"/107" kit using the owners cylinders and CP pistons and he is an S&S dealer so includes S&S cams with his kits, he is partial to the 585. Mike's shop is in New Braunfels, Texas and is one of he best porters in the country. I don't know what Mike's head porting is going for these days but I will be out at his shop next Saturday and will check on pricing for his 98" kit and head porting.
There are three other builders/porters that I trust; Don Dorfman DBA HD Performance; Scott Palmer DBA Hillside Cycles and Kirby Apathy DBA VeeTwin Performance.Having said that, there is another alternative with VeeTwin Performance in Florida. All three offer a basic "street" port job that includes larger intake and exhaust valves, SERDI valve job, new guide seals, milling for the desired compression for the selected cam set (if you choose to replace the 570 which I would probably keep as it is a great all around cam but does need the right compression), bowl blending, port "contouring" and D shaping of the exhaust port but not full porting. These heads will all flow more than the SE Performance heads and the cost runs between $400-$500. They will all work on an exchange basis by charging a "core" charge/deposit until they receive the owner's heads in good condition. They all also offer Stage I, II, III and IV packages and the cost could run up to $1000+.
They will all bore your cylinders to 98", provide CP or Wiseco pistons, hone and fit pistons and gap rings. The cost for this package usually runs about $500-$600.
So, you can Google search on the three shops included above, get the contact information and give them each a call to discuss your project. Talk about riding style, what you expect, exchange program, time required and pricing. They are all professional shops; can't go wrong with either one. You will develop a feel for the one you would like to work with. Distance and shipping cost may be a factor but I don't think it will make a difference.
Like I said, I will talk to Mike and get the information from him but if you would prefer to speak to him directly, the shop telephone number is 830 228-5874.
As for the S&S kit, particularly the 107" kit, I have heard some instances where the cylinders had to be honed .002" or a bit more to true up the bore. I would not install any "kit" without checking the trueness of the bore and the piston to cylinder fitment; I would not install out of the box. I honestly believe you are better off boring your seasoned cylinders for your project.
Let me know if you have any questions; happy to help any way I can.:s
