C cubalz Member Nov 4, 2011 #11 Glider - The picture of label on the box from HD says 11/14/05. Is this what you would consider "later"?
G glider Veteran Member Nov 4, 2011 #12 cubalz said: Glider - The picture of label on the box from HD says 11/14/05. Is this what you would consider "later"? Click to expand... That's usually the manufacture date and doesn't indicate much in this situation, find out the part numbers on both mufflers.
Iceman24 Well-Known Member Nov 4, 2011 #13 Also...wouldn't the SE logo be on "outer" side of pipe so there should be no question on which is which...??
C cubalz Member Nov 4, 2011 #14 These slip ons were made without the Screaming Eagle logo on them. According to my local shop, not an unusual occurance.
G glider Veteran Member Nov 4, 2011 #15 We can "surmise" all day but without the part numbers from both mufflers, we're only guessing.
Dr. Dolittle Experienced Member Contributor Retired Moderators Nov 4, 2011 #16 Iceman24 said: Also...wouldn't the SE logo be on "outer" side of pipe so there should be no question on which is which...?? Click to expand... By George, you're absolutely correct! I just went out to the garage to confirm it and the logo is only on one side of each pipe - the outside! Brilliant!
