The CUSHION off the motor crank-shaft IS a needed thing. Straight chain sprockets do Not hold up nor does the Ride...
Too much Jerky without it (45* off-set 2 cylinders) IF we had 180* off set engine,,, firing smoothly, that
might be ok.
On the King I also have a Rubber insert that allows Cushion right after the engine compensator to the tranny Then RUBBER device for Smooooother flow to the rear wheel...
Seems ALL that is
needed to Equate to SMOOOOOOOOth operation...
I would Not have mine any other way.
That is VERY interesting. Wonder why more people don't just replace the springs?? Even if you had to do it every 10K miles, who cares? Would be cheaper, and give you an excuse to open the primary every once and a while to inspect your ride! BUBBIE, do they even sell replacement springs? Guessing not..
HD Saw REAL MONEY for a complete replacement......
I have, On another forum, a mechanic that said HE did the ordering of New Springs and Used the older Original Comp on Many bikes he works on...
Also saying he added One more spring?....... X-tra spring?.......That I know no more about BUT he said it worked.
Old Comp Spring. is a Round Looking Like a Big washers,,, Big OD and ID,,,,Facing against the original comp. Squeezing and Applying Pressure to hold the com from loose and Banging...
? Might Make a good product to sell and I Know
you would be able to Make Money.
OK, It is all yours
:newsmile100:
