FLTR2008TRIKE
Thanks Hoop... Thanks for posting them
Quote from Steve:
This has been serviced at 1000 miles and has a total of 1461 on it at that point the oil has 461 that you see full of metal. We are seeing wear that is much like what we saw on the old style in the past. Not as aggressive but I do not feel that it is solved and we are working on a kit to provide more oil to the spokes on the new 1014 and up comp
I really think the "A" is my best way to go... No problems yet and Like I said, when down to install my SE clutch spring, NO visual rust. Looked very close but was Not going to take it apart.
I do use MTL by Redline and did groove it to suck in a drop or two of oil..:60:
I also use the Full amount of 40 oz... More MAY help... I have No problems keeping it that full.
Too much oil in the primary can create issues with the clutch not hooking up correctly. Also there has to be enough air volume in the primary for pressure expansion. Otherwise you will get oil puking out of the breather tube
