I just called the dealer and told him to put in the CR. He said I am wasting my money and he doesnt even install them with 255 cams but, if it gives me piece of mind to go for it. Parts and labor around $200.
I hope I am not wasting my money.
Lets say IF: YOU
If the bike you have Needed to start easier FOR an Unusual Reason;Like the battery was LOW. The compression reliefs would allow Easier starting and Just plain Easier on the starter when releases are used..
Or IF : you had to Push start bike(starter out and Bad)out in the middle OF No where.. Compression releases would help there.
I don't think it to be a waste of $$ FOR ME...
I Will install them when my 09 96" goes to 103" just because.
I have NOT installed them When Needed to on a few of my builds.. and Paid a $$ price
Smitty is Right on in his saying about compression. example below:
I have Gone WAY over board on a couple of my builds and PAID$$$$ to rectify a problem in a TC Using 10.5/1 compression along with a good combination in other Hot parts,,,, Only to find I had to go to a special Programable Ignition to retard the spark, even to burn on 92 pump gas...
Good for around home but Not so good as a out in the middle of No-where...
I went thru a Crank (front rod) cause the engine was pushing 215/219 lbs of static compression also went thru Many starter drives(clutch) going bad Kicking back when trying to start a warmed motor after fuel filling stop,shut off... Also damaged clutch ring starter gears, chipping teeth out making More Problems..
Never Installed the Pressure Relief plugs in that motor, but it NEEDED them.(.)
It is just like Cams, BIGGER is Not always BETTER.(.)
I also try to stay around a 10.00 compression for Road riders and 10.25 is still Pretty Much TOO much for a few bike engines and Other Riders.
wasn't it Hobbit that said he preferred Higher compression?? at around 12 area?
