Why shouldn't you get the 10% discount. This is the way it was set up for forum members.
Shift Lever Replacement - Harley Davidson Community
I would rather have the softer metal as the "sacrificial" part of the shifter mechanism rather than having to replace the shift shaft itself in the trans.
I feel the replacement lever by Conrad is the way to go in lieu of pulling the primary, clutch, inner primary etc to replace the original lever with another factory lever. Once opened up, it leaves a lot of areas for problems with leakage etc as opposed to using a die grinder or dremel to remove the stripped lever to replace it with the stainless lever from Conrad.
JMHO
big footed stomp! :bigsmiley20:
One key thing here is besides the idea of stronger stainless part, the other deal is the finding of root cause that is doing the damage. Proper lube and linkage adjustment as well as "normal" shifting practice can reduce shifting problems. Even something simple like holding in the clutch lever before starting and rolling the bike back (about 3 seconds) can make that first shift in the morning to be less of a "bang".
