Hi,
Temporary I have to repair it eg pushing new bearing on spectial stick for placing bearing,
then center it in lathe due here in poland parts are 4 times more expensive that in US, and I have to wait for package with new shell from US about 3 weeks.
Clutch was not disengaging completly for this reason. I think damage was done, becouse some time ago, as I bought this bike, primary chain was very, very tight.
I installed covered bearing (oryginal installed was open), as i've seen currently they are selling covered bearings.
Greetings
Pawel.
Hi,
Now I puted all parts together, still not running correctly, so trying more. And what I found
that clutch is working correctly when i turned in regulation screw 2 turns in.
so final conclusion is that hydraulic clutch is not pushing out enough diphgram spring *sigh*. I have 11/16 more in hand, but maybe slave cylinder is too big. What I'll do now
is to make slave cylinder a little bit smaller. I have to calculate how much smaller it should be to push out clutch about 1mm.
Greetings
Pawel.
