Midnight Reign
several good suggestions here, I have had good luckwith using small thin strps of metal (1/4 wide strips from beer cans work well) or the locktite also works well. I prefer the green loctite for handle bars. But be careful not to be tempted to use the left over for anything that is not permanent, this stuff is EEEEvil, you can get away with it for a handle bar appliction though because when you unbolt the clamps for service or replacement there is plenty of leverage to break the loctite bond, wheresa if you use it on bolt threads you most likely wont get them out without damaging something
