Hoople
Account Removed
No engine lights remain on while running. Everything appears "healthy".
That means nothing. You still can have historical codes. You must manually check. (best way)
Has your friend added an aftermarket fueler of some sort? I would assume he has. A stock Harley with stage 1 is going to run hot. If you have the money add a Thunder Max and an oil cooler. That will drop the temps. You can see your AFR with the Thunder Max and not with the TFI. TFI is all you need with your mods.
My friend mentioned he thinks the larger 96 engine just runs hotter than his due to the nature of the "beast".
Your friend is 100% correct. The "96" can not be compared to an "88" as far as heat goes. He has it made in the shade as far as the heat topic goes. But he has his own other problems that we don't have.
A 2005 pre-O2 sensor "88" with cable pull throttle & Rineharts is not even close to a "96" post-O2 sensor, throttle by wire, with Rineharts.
Hoople,
My ride has cable pull/push throttle with V&H Big Shot Staggered and so does my friend.
While all else fails, hit the entabulator button
Hey Hoople..... what do I do when the entabulator button fails??? :newsmile08:
It appears that everyone here is off topic (again).
