BUBBIE
Well-Known Member
Found the leak. It is coming from between the outer primarmary cover and the innner cover at the very bottom bolt next to the drain plug. So I am thinking it is probably the gasket ( which would be a lot of work for a small leak ) or maybe I could pull the bolt and put some sort of sealer on it and see if that helps. Meanwhile I will just keep wiping it off every so often and ride.
Most of the time UNLESS loose, I would leave it alone And live with it. Taking it out and trying to seal it the way you talk about never worked for me.. Tearing into it the whole 9 yards is a lot of work for a BOTHERING little Drip..... You will someday IF it bothers you enough..Just a Harley Owners' Pride....:newsmile011:
Think of the time it was common knowledge when HD's Marked their spot....
Now that is when they self-oiled the chain or Just Plain LEAKED..
