Actually Hoop figured it out, the air bubbles rise to the highest point, I go a bit farther by gently tapping to displace bubbles that might be stuck in tight turns within, from the caliper, brake hose, (if two, the one farthest from M/C first), crossover, tubing up to the banjo/master cylinder, with the brake lever bungee corded to grip, squeezing lever several times.
Repeat process in the morning, (if you have the m/c cover off you will see additional bubbles rise from the bottom port), THEN release the lever and pump gently several times in steadily firmer strokes and watch additional bubbles rise out. If you see no more bubbles you are done. Only wish the rear brake system could be done this way, but the m/c and caliper relationship is too level and has loops that trap air bubbles, resisting bleeding this way.
In the trans am and camaros, if you replace the master cylinder, you have to hang it over night to let the small air bubbles rise out. No amount of bleeding will do it. Same should work for a bike.
If you have a soft front brake pull, try putting a strap on the brake lever pulling it in tight, and let it sit over night then in the morning let the strap loose, pump up the brake and your brake should return to normal.
Can't wait to try it. I hope it fixes the problem:eam
My front brakes are not spongy. Once the lever gets to the active point, the function is nice and hard. The problem is that it takes over half of the lever travel before compression is detected. I have rebuilt my master cylinder, and fully replaced all fluid during bleeding. Some improvement, but I did not see much wear on the MC seals. Before the rebuild, ineffective lever travel was around 2/3.
I'm told that accumulation on the caliper pistons can cause this. I can't for the life of me figure how that could be. Being an engineer, I need to know the failure mechanism. It seems that if the pistons were dirty, the pads would not retract, causing drag, but I can't see how that would account for the ineffective brake lever travel.
Last unrelated repair operation, the tech at the dealer did something I did not get charged for, that made the brake operation almost immediate in lever travel, but I did not get charged, nor did it get put on the invoice. I did seem to get quite a bit of brake drag in that state, until the lever travel worked its way back down a bit, over a few hundred miles.
I need a mental model of the failure mode. Can anybody help?
Enjoy,
Rich P
