The difference between the softails and touring is that when off the ground on a lift, the touring bikes will self center if you swing the wheel to either side and the softail will not, it has to be coaxed off center and then falls away and stays there.. The softail procedure is a bit different than the touring.
The proper torque for the stem nut is 70 ft lbs.
