Har-D
Well. I replaced the solenoid from the outside of the primary case and when I hit the start button it tried to start initially but then the starter ran continuously, without cranking the engine, until I disconnected the battery. I guess something inside was jammed and not working mechanically to allow engaging of the engine? While I was attempting to disconnect the battery, the starter smoked a little and ran slower and slower (battery dying?). I then had to go into the primary case and see what was doing. I did not see anything special, but I just reattached the solenoid and rattled the inners a little to make sure it was free. When I went to try starting again, it did not run coninuously but made a slight grinding sound; like it tried to start but could not turn over. Could the battery be dead from the running of the starter? I am charging the battery and will try again. It is a HD #65991-82B sealed battery --how do I charge it? I have a 12V charger that can be set to 10amp or 2amp.
Thanks!!! I am trying to make it to Gettysburg this Saturday. Help!
