Just got a used seat from the web at a great price. When I was checking the fit, I noticed the location for the rear mount on the fender is only a hole (with a cap). I was thinking of just swapping out the original one from my two-up seat, but was curious as to how hard it is to install in the new location? Looks like there is not much room under the fender, do I need to but up on a jack to access? If so, is there any benefit of just buying a new one to install in case I want to swap seats if my wife wants to ride on the back? Thinking of flexibility in the future.
Thanks
The seat well nut insert kit is only $6 or so and includes "C" retainer. It is easy to install, I use a medium zip tie, slip thru the insert, feed it up between the tire and fender and into the mid hole, indexing the zip tie end and draw the entire assembly until you can slip the "C" retainer in and your done. Save the HD logo hole cover, and install in the unused location if installed insert is visible...
