hdroadsofa
I did find 1 wire that was pinched and had some wire exposed. I taped it up with electrical tape. all other wires look good. Are there fuses to be checked other than the fuses box?? IE in line fuses??
I think everything right there under the left side cover, they are hard to see like dangerdan said use a multi tester if you have one, but since you found the wire that was shorting you might be ok, let us knowI did find 1 wire that was pinched and had some wire exposed. I taped it up with electrical tape. all other wires look good. Are there fuses to be checked other than the fuses box?? IE in line fuses??
Welcome to the forum customdeuce,I had my motor and transmission seperated for several weeks (2001 Twin Cam 88 B motor). I put everything back together and went to fill in up with oil. The manual says it takes 26 t 28 oz. To get the oil to the bottom of the clutch basket I had to put 42 oz. in it. Any ideas, maybe I wasn't looking at the clutch plates but another part of the clutch. The oil was no where near the clutch inspection opening, but it was toutching the bottom of the clutch. I can't see where it will hurt anything but still would like to know why?
