You arel likely looking at high intensity LEDs, probably surface mounted. The Shack won't likely have them, but, Digikey likely will, if you can determine what they are.
Here is what we know:
- Not all are out, so they are not in series
- Since they are parallel-wired, unless they are supplied by a constant current source or individual limiting resistors, they are current-limited by a single resistance. Once you lose one LED, current and voltage to the rest goes up. They will all wink out one by one from overstress
- If, being in parallel, each one has a single limiting resistor (or built-in), loss of one will not overstress the others in the array.
It is possible that these are not designed to come apart for service. Be prepared to have to break something to get in. Hence, you will have to find a trustworthy means to get them to stay closed up, when/if successfully repaired.
Enjoy,
Rich P
I just installed my LED, running/turn, Harley D. type the ones on SOA, Left side works, but right side doesn't blink.
running works, doesn't blink. If pressed back works, but doesn't blink. What can I do to fix this. JP
