MotorKing, while we have you on the line! (your trapped now!
) Can you tell me a little about the standard HD 6R12 plug. Things like an AutoLite Cross. I believe the 6R12 plug is made by Champion. What is the true Base number for that 6R12 plug (example L87Y, L88A etc). Is the AutoLite cross to the 6R12 plug a resistor plug and if so what is its nominal value in ohms. On the later model bikes, HD uses the Delphi Ion Sensing ignition coil. Will changing the plug, change the operating characteristics of the Ion sensor sub-system?
I have used Autolite plugs many many times in the past with Great results and it is a Very Fine product.
Thank you for any insight you can share with us.
