Sentinel
Well then I rode 50ish miles home from Santa Fe Springs with an unadjusted clutch. I waited to get home to fix it.That should be good then, how far out on the lever before the clutch seems to engage? no grinding when you shift? Your issue maybe just the clutch working itself in and will get better once you get a few miles on it.
As for grinding I do not think so. Bike only has 4 gears, so sometime when I am downshifting, 2 to Neutral is easier than 1st to neutral. And Sometime when I down shift my shift pedal will shake a bit but that might be because I shift too slow and it's trying to be in neutral. Sometimes it kicks into neutral in 3-4 gear.
Also I just went back out to see how far I release the lever before the clutch engages. I'd say about a 1/4 inch and then it starts to roll. I understand it is an old bike, 34 years old, so Should I be expecting a harder ride?
