How about the front brake. My '05 Ultra has been making a noise for about 20k miles. I only hear it when I use it. The dealer told me it was normal. Should I use different brand pads or a grease on the back of the pad (like on a car) when I put new on?
Harley had all kinds of "fixes", start with simplist..."Glazed linings", if you can see shiny areas on your pads when you remove them (Do Glider's EZ Brake Caliper service listed in the service tips" to find out how, then start with step 1...
1) With medium sandpaper and on a flat surface in a circular motion, remove the shiny wear pattern till the entire surfaced flat but roughend up. Rinse with clear water and air dry. Coat the backing plate for the pads with thin layer of noise suppressing Permatex/Copper paste, you will have to push the caliper pistons in their bores to accomodate the additional thickness when you reassemble, bleed the brakes and road test.
2) Replace the pads with new ones if worn within 1/16" of the backing plate or of the "debris groove" in the center is missing (worn to the max safety depth).
3) If problem returns, there was a Service Bulletin on those bikes with dual discs, that you might "swap" the left and right sides. Since the wear patterns are different, my guess is they are thinking the resonance vibration/pattern will wear in and seat the pads differently, also stopping the resonance/vibration sound.
