so cal hoss
Thanks to all for your feedback. California doesn't require an emissions test but many cities are now starting to check for original compliant stamped exhaust systems. No doubt a stage 1 is in my future.
Thanks to all for your feedback. California doesn't require an emissions test but many cities are now starting to check for original compliant stamped exhaust systems. No doubt a stage 1 is in my future.![]()
Instead of disconnecting the TFI, could you not just set the green, yellow, and red pots back to minimum, and reconnect the O2 sensors and be good to go?If you go with the TFI, It isn't that big of a job to reverse the plug-ins to use original HD's Too Lean condition and the 02 sensors re-plug to "Pass their test" then switch back to the Good stuff with very little work..
I think the V&H slip-ons comply but ? on the air.. But Much leaner than the stock HD to start with when un-doing TFI.
Just my thoughts.
Enjoy,
Rich P
