SE6A
If the air filter has been upgraded the when you remove the cover the filter will be mounted to a flat plate usually with three bolts rather than sitting in a plastic enclosure with the filter cover screw holding it all in place
Thanks Brian..I have a day off tomorrow, so I will take a look.
Have a slight leak at the top of one fork leg...so have to drop the wheel out and check that out too!
