J
Jack Klarich
Guest
Not trying to give you a hard time but why wouldn't a performance cam increase the engines volumetric efficiency at cruise speeds also? Your saying the cams will increase the engines ability to be an air pump only at wide open throttle, and that is not true.
But none the less, it sounds like you have a good plan in place. I am sure everything will go as planned but when in doubt, go a little extra rich than lean. Yes, you will use a little more fuel and you MPG will drop but the engine will be happier. It takes a lot to be toooo toooo Rich....![]()
Hoople is right here, always better to be a tad rich than lean, may save you from burning up an expensive engine
