Late night last night, I am still sleepy, can I go home now
You are allowed to have a nap now and then seems to me that with every passing year i need to rest more often
Well guys
Who Guessed ::::
Drum roll :::::
The drive sprock on the crankshaft is no longer conected to the crankshaft ?
There are 6 splines that are too small (crank) or too big (sprocket). There is a little bit of metal shavings in the bottom area. And one off the magnets is broke and loose , also an second magnet is loose.
What a mess!
Here is a Question : Is there a bushing (sposed to be) between the crank and the sprocket it drives ? Clue; there is fixing to be one there !
Maby the better question is does Harley make a bushing to fit between the crank and the sprocket it drives ?
All input is aprecated .
