J
Jack Klarich
Guest
The problem was never with the starter, the problem is the direct result of the compensator sprocket. You should have the SE compensator sprocket installed, the SE compensator cost around $250 and the dealer should charge 2 hours to do the repair. You are going to have a tough time getting it covered by warranty when the warranty plans says 2 years that means 2 years and the law is on the side of HD on this one.
Call Customer service, if you have documentation they will listen, Good Luck:s
