anybody know shovelhead wiring?
I am wiring a round style mechanical starter relay for my 77 flh. It was incorrectly wired for electronic ignition so I am going to the original point ignition. According to my manual the original relay is a three post style with two wires(positive battery and ignition switch) going to terminal #1, one wire(starter button) going to the #2 terminal, one wire(starter solenoid) going to the #3 terminal, and one ground wire from relay to tranny stud. The instructions from the relay itself; which is a Blue Streak name brand, is not as clear. It states connect positive battery cable to B terminal (large post), connect starter motor cable to M terminal (large post), connect ignition switch lead to S terminal (small post), connect coil lead to I terminal (small post), and If original switch has only 3 terminals- B, M, & S, do not use "I" terminal.
As you can see it leaves it open to interpretation, so my next question is:
If I try to do trial and error connections, will I or can I do damage to my electrical system?
the blue streak relay is part # SS598X
