free website stats program Starter Stall On Startup | Page 2 | Harley Davidson Forums
Mr. Data,thanks for the advice on carbon-does the water stream idea work on efi engines?
will this hurt an efi motor? will seafoam hurt any of the sensors??
Sea Foam is the way to go.. I put some in my fuel tanks of all my vehicles.
Sea Foam Deep Creep is an other good way to remove the carbon from your cylinders..
Will this work with EFI motors? Can this be gotten at any auto parts house?
Sea foam, Marvel mystery oil or the water trick will work on any motor and can be had at most parts houses or auto supply stores.
Water spray has been very good at breaking up carbon, the key is to keep the idle up and steady use a fine mist just enough to not stall the engine, you will be surprised at the results
