Mongo1958
Junior Member
What is Fretting?
from experience. stock comp kicked back on hot starts. Changed to SE comp problem solved on kickback, still get occasional dead stop on start if one cyclinder finishing a compression stroke. anyway then the grinding started and had the starter clutch go rather fast, perhaps 20 more starts.
IMO HD would not be going to the third SE Comp if the stock comp was not causing a suspected problem.
I plan this winter to pull the primary and check for the fretting often discussed, but other than that the 08A comp is an improvement
