i tried to find that post and couldn't
I had a similar problem with my '94 FLSTC. My problem was the starter switch. It had some corrosion build up. Installed a new switch and problem solved. It could also be a worn pin connection at the relay.
when I hit the switch I can hear the solenoid click
if your battery is good.
if u got injectors
maybe fuel pump is weak you have low fuel pressure until running or a leaky fuel pump regulator (pressure not held, so when you start it has to build). replace that junk
that's one of many possible, common on what i used to work on.
if u got injectors
How would the fuel pump pressure have any thing to do with a slow cranking engine???? Explain please.......
some starters have built-in electronics (voltage regulator? heat protector? and etc)
if you have immediate power to starter: it's the starter that's delaying probably the electronics
starters do fail occasionally and a good number are replaced due to not having replaceable electronic module (or improper diagnosis).
