Bud,
I might be interested in doing this on my bike. Is there a conversion kit to do this? If so, can you send me the part number for it?
I sent this to Joy but I'll post it here too.
2 matching fork legs PN 46502-06 (right $186.84) and 46495-06 (left $186.84) which are complete forks with sliders and internals with fluid too and just install them on the bike and be done with the cartridge problem forever.The later year 2007 fork legs have a better valving system than the earlier ones for a better ride and can be swapped as with the early year legs and should also fit your bike but this would require replacing both legs complete. (best way to go). Cost is somewhere around $300 for both with a discount at Zanotti's.
You can get the parts separately to convert your lower leg to the non cartridge type if you want to get into it.
The sliders for 99 - 06 are all the same
P/N: 45803-97 STOP, oil lock ($7.14)
P/N: 45838-77 BOLT, front fork ($.18)
P/N: 45845-77 O-RING ($1.75)
P/N: 45859-77A RING, piston damper tube ($1.10)
P/N: 45890-97 TUBE ASSEMBLY ($47.11)
P/N: 45891-97 DAMPER tube assembly ($9.95)
P/N: 45892-02 SPRING, fork ($21.20)
P/N: 45933-86 SPRING, rebound ($2.40)
P/N 45875-84A two new seals, ($8.66 X 2)
Verify these numbers for your bike before ordering them TQ
